HAF X Front Fan Mod
Watcha think guys?
Noctua NF-P14 with custom LED.
That is pretty Cool! I like it. We never saw orange fans, they are allways red, blue, or something else.
How many Leds have you use?? can you do a kind of tutorial how to Mod the Noctua Fan???
I really like it XD
EDIT:
Wait a minute, you drill the entire fan?? for each LED??? XD Crazy guy, but is the best option yeah =)
Hi dude,
Only just saw your post sorry!!
These are the only ones I can find - no idea what happened to the other ones hosted here??
Wow never thought of this, i actually have a green lit coolermaster 120mm on me right now i could use, or i have a noctua 120mm i bought as a case fan i can use.
I modified the front 230mm fan on my HAF X and changed the LEDs for bright green ones as you can't buy a green megaflow, so this could be good
I ended up using a 120mm on the 3 bays, but its helping
.. now I just need to learn how to overclock
Anyway, thanks for the pics =D
Hey guys i've just completed mine in a small amount of time, didn't have enough cable ties though so had to go buy some, i think i have the fan raised to high though, i will experiment with temps by changing it over for a noctua shortly.
EDIT: I changed the Coolermaster fan as i wasn't happy with the position i had it in, plus i wanted to try the Noctua NF-S12B FLX i had lying around, temps were better straight away, think it can stay in.
Hello =),
so, this is how mine looks like:
ps: about the dust filters, cleaned 2 days ago and they already look so dirt =/.
Im liking the temperatures, not sure if they are good =d
i7 2600k @ 4.6ghz - 1.38v --> Ambient 29º-30º. Core highest temps after 25 hours of prime95 - 62 67 66 64.
I wish I could get to 4.6 with a lower voltage =[, but everything below that was failing on Intel Burn Test set to max =[[[ (Prolly because I dont know how to tune the bios setting correctly =D)
People are still reading this? Hahah. My fan's still doing nicely. That filter idea is pretty good, though. I do have a lot of dust collecting from time to time.
