Hackintosh build!!
KING_OF_SAND
As we all know Apple likes to keep things VERY exclusive to its OS’s. Anyone who is a techie will know there is no such thing as VERY exclusive, just slightly exclusive :P
Over the course of a few days my brother and me were doing research on my current build:
Motherboard: Gigabyte GA-Z77X-UD5H (100% operational in OSX)
CPU: i5 2500k (100% operational in OSX)
RAM: Corsair dominator platinum 1866 (100% operational in OSX)
GPU: GTX680 (100% operational in OSX but has performance issues)
HDD: WD Blue 320gb (YOU MUST GET A SEPARATE HDD!!!)
After a few days of research via Tonymacx86.com we found that every part was compatible, and some only with a few edits via a program called multibeast. (Later explained)
Before I go further in depth, here is a photo of my “About This Mac.”
As you can see everything is showing up, including the correct speeds of the RAM and CPU. But the CPU did not just work right away. In fact neither did the GTX680. In order to get every part of my motherboard working I went to (http://www.tonymacx86.com/user-buil...h-16gb-ram-2133mhz-gt-640-a-4.html#post456037) This gentleman had about the same rig I did in fact the majority of Hackintosh users have a VERY similar rig. This is because Gigabyte out of all the motherboards is the MOST preferred partly because it requires no BIOS modding and my Motherboard in particular has a BIOS switch, one for Windows the other for MAC (it is not recommend you dual boot unless you have a profile saved for Windows in the BIOS).
As for the video card I did mention that it does have performance issues and that is because the GTX680 is not a supported video card by Apple. BUT there are two methods to get it working at its appropriate clock as well as get pretty decent frames in all the games that are on Windows that are also on MAC; for example Borderlands 2 is playable at 60+FPS, Batman city 60+FPS, L4D2 60+FPS all maxed out. One way is to use the driver that is used on the mobile 680mx, which is an Apple only mobile 680 chip. And the other is to use this (http://www.nvidia.com/object/quadro-macosx-256.02.25f01-driver.html) Yup even though it is not on the supported list it works just as well as the MX chip does, and this is what I used. Before I go on the process here are some bench scores:
Geek Bench: (http://browser.primatelabs.com/geekbench2/1639789)
Unigine:
As you can see I am running this is DX10 (DX11 does not work in Unigine MAC) and everything is MAXED out at 1080p. Not as high as you would see in Windows but pretty good considering the condition.
Cinebench:
HWmonitor:
This is 2500k at 3.4ghz max frequency. (I will be overclocking soon)
So I have been doing some more fine tuning and it appears that my 2500k was only running at 3.3ghz MAX. I adjusted some BIOS settings and got it to go to 3.8ghz which didn't do much but did enough to have my geekbench2 go up a tad.
Well I guess I shall give you all a quick rundown on how to get Hackintosh working. But for starters I am NOT liable for any data loss if you format the wrong drive or if you brick you BIOS for those using anything other than a gigabyte board.
As mentioned I am using the Gigabyte GA-Z77X-UD5H and 100% of it is working including both the NICs. You will need a new hard drive for this dedicated for MAC OSX and you will need to use a different BIOS profile for MAC as for Windows or you will BSOD Windows when entering it.
The tools:
You will need for starters Unibeast for Mountain Lion
(http://www.tonymacx86.com/downloads.php?do=file&id=162)
This will allow you to put Mountain Lion on a bootable flash drive (the flash drive will be formatted in the process). Here is the kicker, you can only obtain Mountain Lion through OSX Snow Leopard which means you will need to download Virtual Box or find a Mac with Snow on it. I did the VB way and used my Uncles Snow Leopard. (there is a special way to get SL to work on VB).
PLEASE do not pirate it. Not only will lose all respect by those of Tonymacx86 site but you will probably have problems with. So basically if you can find someone with SL you will only be spending $19.99 on this whole process if you already have the compatible parts.
Which brings me to my next point, parts. As I mentioned I used a Gigabyte board that is 100% compatible. Here is a great place to get you started (http://www.tonymacx86.com/325-building-customac-buyer-s-guide-january-2013.html) on finding the parts. For the most part if you have an intel gigabyte board chances are you are either 100% or near 100% compatible already. For those with other boards I would do some extensive research as most other brands require a special BIOS be flashed on the board, in which case you will only build a Mac computer.
Once you use Unibeast to put OSX on the flash drive the remaining install is pretty much straight forward. But before you install you must format your blank drive correctly or the installer will not read it or even recognize it. You will need an HFS format on the drive and there are utilities that will do that for Windows. Or you can make it into an NTFS and format it in the installer. Either way it needs to be in some kind of format or it will not be read.
No matter which way you roll you will need to create a new working partition for Mac. So now that we have the format sorted out it is time to boot from the USB with Mountain Lion. When you select USB you may see multiple options, select "USB".
Once you boot via USB and get to the main screen you will want to go to utilities on the top left and partition the drive. Once in, select the partition tab and select partition 1 name it what you want, make sure you have selected "Mac OS Extended (Journaled)" then click Options at the bottom and make sure GUID is selected. Now exit that, click the proper drive and install. It will take about 20 min. (WARNING: The screen may go blank to the end this is normal!. Keep an eye out on the HDD indicator light, if it is flickering it is still installing. Also keep an eye out for the restart and press what ever key it is to select boot options. SLECET USB AGAIN!!)
STOP!
The reason you want to select USB again is because the OS is not able to boot by it self yet.
But this time instead of selecting USB in the USB boot, select the newly created Mac drive.
Yes booting from the USB via BIOS will bring up more boot options, please select the correct one!
In order to boot without the USB you will need a program called multi beast, another tool. (http://www.tonymacx86.com/downloads.php?do=file&id=155)
You can install multi beast via your operating OSX from Safari you can try putting it on a flash but your USBs may not work. You will also need an account to download anything in case you have not already figured that out.
Once multi beast is downloaded select "UserDSDT or DSDT-Free Installation." This will allow you to boot without a USB. Of course you have to make sure your BIOS is configured correctly. After you are done with that find out what your motherboard needs installed to function 100%. Now you can restart and in your BIOS boot options select the drive with Mac on it.
I will be posting what I did to my BIOS to make it work. IT WILL DIFFER BETWEEN BOARDS!
ive been running a Hackintosh in a VM for a bit now. very fun to use and to learn. i know little about Macs so it was nice to learn about them, while not having to drop $2000 on a Mac lol
