Hello,
I have a complete pc build with H440 NZXT case. The issue I am experiencing is that the GPU (980 ti HOF) is reaching fairly high temperatures arround 75 degrees celcius. When I remove the front case panel with the filter and leave the front fans exposed the temperature drops arround 8-9 degrees! This clearly indicates that the case is becoming too hot due to inadecuate airflow.
So I am thinking of
1. placing 3x NF F120 static pressure intake fans in front replacing the stock ones. This will allow more power in front to overtake the front thick case panel.
2. Place the stock 120mm fans on top as exhausts and also leave the stock exhaust 140mm fan on the back of tha case as is.
Do you think this is a good move? Would this keep the temperatures down?
Should I also replace the back 140mm exhaust fan with a better Corsair AF140?
I am only using air cooling in my build. I have a dark rock pro 3 cooler for the CPU.
Thanks
So I am thinking of
Thanks
