Remember it's not the speed but the voltages that create heat. I believe on Haswell anything above 1.2/1.25 volts creates a LOT of heat. Basically if you can achieve your target speed within these voltages you should be ok with your H110.
Hope this helps![]()
What are your temps like?
I can't run push pull in my case unfortunately so will just have the one set of fans.
Also hoping to be able to run My ram at 2400 if I can. Fingers crossed I win the chip lottery!
4.6GHz here with 4x4GB 2133MHz ram and in games 70c maximum on H100i push/pull 30% fan speed. I haven't tweaked/fine tuned anything as of yet and I won't be until I get my loop set up with a MO-RA3 420.
Also, maybe I got unlucky, 1.36v for 4.6GHz...
What are your temps like DiceHunter? How are you finding the Sabertooth?
I'm yet to pick up my Chip/Board/RAM and probably won't be for another 3-4 weeks unfortunately, but really looking forward to this new build.
haswell will not run 2400 ram OC'd.
