I just assembled my new black Bitfenix Prodigy:
CPU: i7 3770K
CPU cooler: Corsair H100i with 4x Corsair AF120's (push-pull)
RAM: 2x Corsair Vengeance 4GB DDR3 CL8 (now 1x though)
Mobo: Gigabyte Z77N-WIFI
SSD: Samsung 840 Pro 256GB
GPU: Club 3D HD 6870 1GB (until my GTX 670 FTW SIG2 arrives)
PSU: Corsair CX 600M
Now, the tubing of the H100i is pushing rather much against the RAM if it's in the closest RAM slot. (It gets bent about 20°...)
Fitting the H100i's @180° won't do the trick as well, since my GPU will be in the way.
Now, since having only 4GB RAM with an i7 setup is quite useless, I was thinking about going single channel @8GB, but I just wasn't sure if I'd try fitting the extra 4GB RAM in the closest RAM slot first.
Should I risk inserting the RAM eventhough it gets bent?
CPU: i7 3770K
