h100 tube mod
So you want to cover the existing hose not replace it?
Would you not have to disconnect the hose anyway to slip on the new hose? so replacing it would probably be a better option.
If you still want to cover it measure the widest part of the existing tube and find new tube with an inner diameter that will fit over it.
I'm not sure if 10 mm (which the tube you linked is) will be big enough, but with a quick measure you will be able to tell.
Hope this helps :)
Hope this helps :)
You Split the new hose down its length to slip it on, I don't think 10mm will be big enough looing at mine, think its 1/2 (13mm) you need as a minimum for it.
http://www.ebay.co.uk/itm/8-49-EUR-...K_Computing_Water_Cooling&hash=item3f28f99a2d
Hope this helps :)
Yeah ones its cut it should slip on. Will measure the hose and check the size before buying. Thanks
