H100 Temps?
TAWN
Hey all.
My H100 runs very well in my opinion.
I'm getting 19° - 23° idle temps.
Running a 965BE @3.60Ghz
Just wandering what anyone elses temps are like with a H100?
I had a Hyper 212+ and could only get my 8150 to 4.4 because temps would hit 62C. When I got my H100 I fired up OCCT and was in the low 40's on medium fan setting! I thought that was pretty outstanding because while a Hyper is not high end, its definitely no slouch.
On a day where we had 38-40 degree heat, my H100 was keeping my CPU to a temp (under load - albeit not full load) of ~28-30 degrees
Edit: This was with fans set to ~1500 rpm
Unless you've found a flaw in the fundamental laws of heat transfer, i'm guessing the room in which you keep your computer is quite a bit cooler than 38*C.
I'm not sure what the temperature in the room was, but I do know that there was no fans or anything like that in the room. It was definitely uncomfortably warm, since I was sweating my @$$ off.....
Edit: doing a quick check internally vs externally (in the shade) shows ~10*C difference in temperature, with the outside being the hotter of the two. So I guess that the temp in the room would have been ~28 degrees. This is of course, just a guess...
Hey all.
tawn, your idle temps seem ok, but they are idle.. the more important question is what are the
temperatures under a load. this will determine how functional the system is or is not.
airdeano
Which would tend to support my guess (in my previous edit) as to what the temperature was....
we kinda like to have facts, rather than a guess. it tends to raise crediability and
may confuse others.
you see how it can ire the conversation if a piece of information is skewed and
others may call BS.
we do enjoy others to join in with technical help, but mighta and coulda aren't really
helping.
airdeano
Hey all.
Idle temps on AMD mean nothing. TBH you spent £100 on a CPU cooler when really you could have spent that £100 buying a 1090 or 1100T
Hey all.
Idle temps don't mean much unless of course you turn your pc on and it is like 1million degrees, heh.
But really, I clocked my 2500k from 4.5 to 4.8 and going past 4.6 I needed quite a bit of a voltage increase.
With a H100i my idle temp increased quite a bit, from around 22-24c to 33-35c but load only 3c, going from 58c to 61c. When comparing temperatures always look at load.
True.... Paid 70 for it new off eBay as my H60 was stuffed but now that i have a Gigabyte 990fxa-ud5 (had a 880ga-ud3h) i will hopefully soon be upgrading.
Any way of benchmarking my CPU not using 3Dmark11? my graghics card is too crappy for it to run...
I prefer OCCT. Its basically an all-in-one stress tester. Tests everything from the CPU to GPU to power supply and has a nice monitor system too so you can see what your rig is up to.
K, so..... Using OCCT with a room temp of 19°C i got max 39°C with 2x SP120 fans on 1400rpm. Not bad???
i5 2500k 4.6ghz the highest I have seen is 56c and that is running 5 hours of prime. but gaming I hover around the 48c mark and the occasional 52c.
yeah that's pretty good... I think i'm gonna leave this topic until i finally actually have a decent system........
