GTX460 1GB with 768 MB in SLI???
sweet! good to know that it doesnt incase other ppl come here and ask
u able to do a screenie like i did of the properties of the 460 in device manager and in the hardware id drop down?
too see what the differences are
Wicked cheers lads
Another OC3D mystery solved
aright guys i just wanted to know if i could use my gtx 260 for physics with my gtx460's in sli both the 260 n 460's are gainward golden samples or should i sell them n with the proceeds get myself 2 gtx 580s i know the 580's would be awsome its just ive seen this mentioned about useing differant gpu's several times now how much of an improvement would i see? any helps always appreiciated:D
if u have 3 pci-e's mate slam the 260 in there download the drivers for it and ur away mate
but once there in and drivers are installed go to nvidia control panel and make sure the 260's dedicated to physx to be sure and thats it sorted
as easy as that? lol will there be much ov an improvment if so i can save them pennys fo some new ram n a noctua nh d14
b4 them vat rises
yeah there should be a decent hike try it mate if u dont think there is then take it out sell them all and get a 580
yeh just had a look on nvidia site they on the same drivers just one more thing while i think on i have the 3d setup it wont mess with that will it? n1 thestepster goin give it a go anyway soon find out lol:D
thanks thestepster its in there tight fit not alot of room at all goin run 3dmark vantage see how much off an increase there is i'll post some results later cheers m8:D
no probs dude! one thing u might want to do since there all packed together get a 120mm fan and sit it on the side if possible so it forces in a little bit more air to keep the temps down
Bear in mind that you're only going to see an FPS improvement in games that run PhysX, and nowhere near all of them do, while dual 580's would get you a huge improvement in all games.
and at least an £800+ hit in the pocket and no games out there except things like crysis and metro will really warrant that kinda power, 60fps and ur sorted for any game
tbh im goin to stay with the 460's n the 260 for physics for now ive ran 3dmark vantage in its hitting 60fps in 3d well impressed only getting 35/40 b4 i may invest sometime in the future though as i cant use phisics for benching scores anyway for now i'll treat myself to the new mushkin ram n the noctua nh d14 for crimbo thats if aria still got stock n1 dudes for your comments n advice:D btw black ops is awsome in 3d n so's f1
if only i knew how?
im completely new to the overclocking n benching scene ive had a look at this folding @home but dont know how to go about it. i would like to have ago though, think ive been graced with begginers luck lol it would be good to put my system to he test. also could do with some help on how to overclock my graphics cards ive got the 460 gs glh x 2 n a gtx 260 gs glh when i try to adjust the shader clock or core clock useing expert tool it says vga graphics may become unstable n resets its self. as ive said im new to the game so am very unsure of settings to use and how to get the best out of my graphics? once again any comments or advice are very much appreciated
Sorry just read this reply, i will do so tomorrow matey
On a very heavy training at the moment and later when i am finished and clean , i am going straight to bed
