hi everyone, im at a bit of a loss. I was having some power issues, so I RMA'd my Corsair TX650M and now the new one is back the power issues have gone. However, I was also having random graphics card crashes that I had put down to the PSU doing some crazy stuff but now that's been changed my graphics issues still remain.
I have 2 x Gigabyte GTZ 770 windforce cards, the error happens on both so its not the cards (haven't run them in SLI as I cant even run them on their own)
I put the card in, load the latest drivers and I get the following
The description for Event ID 14 from source nvlddmkm cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
\Device\Video7
0096(1ed8) 00000000 00000000
this happens when browsing, and if I eventually get into a game it happens then too! right now im using the on board graphics and everything is fine, ive run IBT so its not the processor.
So im down to RAM, mobo or drivers.
I go to control panel and uninstall the drivers and then restart and install again but its no good.
im about to try some older 320 drivers but I doubt it will help.
Im running Haswell
TX650M
Z87X-UD4H
16gb G.Skill Ripjaws at 2133
and im totally lost as to why this is happening.
Any ideas?
\Device\Video7
Im running Haswell
TX650M
Z87X-UD4H
Any ideas?
