Thanks mate and i will report back ,Ray, I get usually 19.5k to 20k PPD on my 680. Been this way since it started working. I'm not sure if Stanford is still working on those infamous "kepler optimized" WUs or if this is the best we can expect.
Let me know how it works out for you.
I must be thick but could you show me that directory where i should paste the GPUtxtFirst you need to do download the GPUs.txt file and put it in the proper directory:
http://folding.typepad.com/news/201...gpus-such-as-kepler-in-the-v7-fah-client.html
After that you need to go into the v7 client, configure, pick the gpu, go to advanced and add client-type beta to your flags. You should delete any work for the GPU the v7 may have downloaded previously. Lastly, close and restart the v7 client.
When it starts up the 680 should be seen properly (Kepler GK104) and it should download a WU and start folding.
I really feel like a idiot as i go there but i can't paste it in that directory ?!Go to start, all programs, fahclient, then click the Data Directory link. IIRC you put the file in there.
This is what i am doing,You're clicking the shortcut in the start menu right? It opens up the folder. You should see other folders within it like "work". You're not trying to paste directly to the start menu are you?
Weird, you should be able to then copy/paste the .txt file right under sample-config. Do you have the correct permissions for that directory? Try exiting completely out of FAH before you open up that folder.
I am going nuts :mellow:Weird, you should be able to then copy/paste the .txt file right under sample-config. Do you have the correct permissions for that directory? Try exiting completely out of FAH before you open up that folder.
BTW: The GTX 680 can work as two GPUs if you add it as gpu-index 0 and 1 it's running as gf:114 and gk:104 at 37-45k PPD![]()
hmmblah have you tried that with the 2x GPU thingy,
quote from another forum,
If this is true , i thought i already mentioned it ones.......
but i can't try it yet , i hope to have something working later this day.........
LOL here i am again :lol:,
was there also some kind of issue trying to Fold on a GTX460 ,
that gets his PPD cut in half right next to a GTX680 ,
which is NOT Folding at all
Thanks for the reading guys, darn it.. am i beeing annoying in here :nopity:
when i get it to work i'll buy a second one(GTX680).. if that solves the PPD problem :wub:
how are things loking with your 680? you getting good numbers from it?
