Gripen90
Hi y'all
I just thought I'd post my "pc time log". It's how I've upgraded my PC through 2009 to 2013 (roughly).
I'm still using the same case and by todays standards it's not popular and I do get a lot of negative comments about it. When it was out in 2008 the hype wasn't about cable management at all but airflow and decent looks.
I still love this case and therefore I haven't replaced it yet - simply put I haven't found another case which looks appeal to me. ^_^ ... yet !
Cable management can't be done "efficiently" as such, but the airflow is fine inside :crazy:
Year 2009.
Graphics setup: 2x MSI GTX 280 OC Edition 1GB & 1x Realtek GTX 280 1GB
Quick Specs: Asus M4N82 Deluxe, 8GB Crucial BallistiX PC6400 CL4 Ram, AMD Phenom II X4 955 3.2GHz Black Edition.
Case: Cooler Master CM 690 nVidia Edition.
Case Cooling 2x 120mm 200rpm front intake fans, 1x 120mm 1850rpm in front of graphics cards. 1x 80mm bottom intake fan 2000rpm. 2x 120m 1800rpm top exhaust fans, 1x 120mm rear 1800rpm exhaust fan, 1x 80mm 2000rpm rear atx motherboard intake fan. 1x120mm intake side panel 1200rpm fan.
Year 2010.
Graphics setup: 3x EVGA GTX 470 SuperClocked 1.25GB
Quick Specs: Asus M4N82 Deluxe, 8GB Crucial BallistiX PC6400 CL4 Ram, AMD Phenom II X6 1090T 3.2GHz Black Edition.
Year 2011.
Graphics setup: 2x Gainward GTX 580 1.5GB & 1x PNY GTX 580 XLR8 1.5GB
Quick Specs: Asus P7P55WS Super Computer, 16GB Corsair XMS 3 1333MHz DDR3 CL9 Ram, Intel Core i7 870 2.93GHz
Case Cooling 2x 120mm 200rpm front intake fans, 1x 120mm 1850rpm in front of graphics cards, 1x 120mm 1350rpm intake fan in front of CPU cooler. 1x 80mm bottom intake fan 2000rpm. 2x 120m 1800rpm top exhaust fans, 1x 120mm rear 1800rpm exhaust fan, 1x 80mm 2000rpm rear atx motherboard intake fan. 1x120mm intake side panel 1200rpm fan.
Year 2012.
Graphics setup: 3x Club3D GTX 670 2GB
Quick Specs: Gigabyte X79UD3, 16GB Crucial BallistiX Tactical 1600MHz CL8 DDR3 Ram, Intel Core i7 3820 3.6GHz.
Year 2013.
Graphics setup: 2x MSI GTX 780 3GB & 1x MSI GTX 780 TwinFrozr Gaming OC 3GB
Quick Specs: Asus P9X79 Pro, 16GB Crucial BallistiX Tactical 1600MHz CL8 DDR3 Ram, Intel Core i7 3930K 3.2GHz.
Year 2009.
Year 2010.
Year 2011.
Year 2012.
Year 2013.
