Graphite 600T question
Mgutierrez33
Here's one I just thought of: one of the possible build schemes I want to use for my Graphite 600T requires more than four fans. This wouldn't normally be a problem, except that I would have liked to use the integrated fan speed controller that is already ON the case. Has anyone attempted to use more than four fans on one of these cases, and if so can you relay your experiences with it/fires that have been started (if any)?
a freind of mine has one when he treid six fans using a splitter it wouldnt work probably because corsair set a certain limit per channel and 4 channels is more than likly the max of the onboard controller.
if you want to use more fans your better off getting a dedicated fan controller than can actually handle it most dedicated controllers have 8 channel maxximum pcbs :D
Yeah that's what I was afraid was gonna be the response lol. Thanks for the input mate! Now to plan my next move with the projected build x-)
