Am kicking around an idea for TECing my 6600GT (not high-end, I know) and have seen that there are problems with throttling below 25celcius as the card thinks its too hot.
Some people think the throttle temperature is decided by: core temperature maximum-100 degrees. My core threshold is set at 145 at the mo (which I cant change), which is higher than my card idle temps on a cold day (hopefully not gonna have many of them for a while)
Anyway: the point/ the question.... does anyone know how true these points are? Are there any BOIS hacks I could do to change the threshold temperature to...say...90celcius (90-100= -10) (much better) Failing that, If I could change the voltages to my core and memory, that would keep temperatures up a bit and prob lift the bar for overclocks...does anyone know any tricks for volt-modding a 6600GT AGP?
The TEC is just an idea for a spare watercooling setup I got, but the BIOS hacks and volt-mods i`m interested in anyway.
Thanks a lot,
Kenny
Thanks a lot,
Kenny
