GPU for adobe premiere pro
antlear
Hi I recently built a new computer but never got a gpu as was a bit confused. I used adobe premier pro to edit videos but have a limited budge. I have upto £120 to spend on a new or second hand GPU, what should i go for.
I have seen the nvidia geforce 550ti would that do.
thanks
ant
This is what Adobe lists as supported cards:
Supported NVIDIA graphics cards for GPU acceleration
GeForce GTX 285 (Windows and Mac OS)
GeForce GTX 470 (Windows)
GeForce GTX 570 (Windows)
GeForce GTX 580 (Windows)
NVIDIA Tesla C2075 card (Windows)/Maximus configuration
Quadro FX 3700M (Windows)
Quadro FX 3800 (Windows)
Quadro FX 3800M (Windows)
Quadro FX 4800 (Windows and Mac OS)
Quadro FX 5800 (Windows)
Quadro 2000 (Windows)
Quadro 2000D (Windows)
Quadro 2000M (Windows)
Quadro 3000M (Windows)
Quadro 4000 (Windows and Mac OS)
Quadro 4000M (Windows)
Quadro 5000 (Windows)
Quadro 5000M (Windows)
Quadro 5010M (Windows)
Quadro 6000 (Windows)
Quadro CX (Windows)
That's not to say you can't get other cards working, but to be certain stick with one of those.
http://www.adobe.com/products/premiere/tech-specs.html
moved to GPU section
afaik any cuda able card will work.
do note that not all nv cards support cuda as it has a min hardware req too.
Anyone know if it's possible to have say a 580 and quadro 4000 in one rig, using one for editing etc with premier or whatever and to use the other to play games?
