Hey, I am planning on water cooling my GPU and was wondering on how to do the loop, at the moment I have planned this for the CPU Loop:
Custom Water Cooling Set up - EK Supreme HF Waterblock - Laing DDC1+ Ultra Pump 600 L/hr with EDIT: XSPC Dual Bay Reservoir - Thermochill TA Series 360mm Triple Radiator - Compression Fittings 1/2 inch - Clear Tubing 7/16 - Mayhems X1 Premix Fluid - Mayhems Deep Blue Dye.
Then for the GPU I was planning on using the same pump/reservoir but have another 240mm radiator at the bottom of the case but I'm not sure on how to connect the entire loop together.
The main point I was wondering was whether I need another pump or reservoir if running a 2nd radiator?
Or could I even cool both my CPU (I7 950 OC) and GPU (GTX 580) from just a triple rad?
I'm not sure on this so would really appreciate some help
