PepperNinja
Hi guys,
Last time I posted was for my personal build and the advice here was super, this time I'm wondering if you could help me out for a friend.
He'll be using his machine for games and photoshop.
We put together a machine, but we need advice with the GPU.
I'm aware that the CPU and 840 pro are probably overkill.
The 32GB ram should be usefull for Photoshop and running some VM's.
The 1000W PSU was choosen because we'll also be putting in older HDD's and neeed to make sure we can power everything.
The main gaming screen will be a 27" with a 2560 x 1440 resolution. On the left and right will be smaller screens, but those won't be used for gaming.
Originally we went for 2x GTX 670 (2GB), but considering the 27" & high res, wouldn't it be better to go with 4GB cards?
But if we look at 670's with 4GB and double the price, we start getting into the range of a 690, so why not pick that.
*Also, if we were to go with a 690, will it be possible to use the GPU with MVP's Virtu Technology?
It won't work with a SLI build, but a 690 is still only one card using one PCI-e slot, so I was wondering.*
Any help would be much appreciated.
If you have any other remarks on the build, please tell what and why you would change it.
Thanks in advance.
[UPDATE]
Nvm about the MVP Virtu, the limitation is dual GPU not the slots.
So that won't work.
I've also been seeing reports that the new AMD cards are better for CS6.
Any ideas?
Thanks in advance.
[UPDATE]
So that won't work.
Any ideas?
