GPU advice for new build.
Very good choices. Watch the RAM, you seem to have added two 32GB kits. In case it's a mistake, rectify it, in case it's not then... Good Luck! :)
Seems solid! Though the RAM is in there twice. It's already a 4x8GB kit so buying two would give you 64GB of RAM, that's
1 - Way over the top
2 - Not supported by Z77 boards (they only have 4 dimms and support up to 32GB of RAM)
The rest seems pretty damn good to me :)
Hehe, must've added it twice. :)
Adjusted the post.
Yeah, I figured it was a mistake :p
Good set up now! Personally wouldn't change anything about this (except I'd grab the MSI Z77 MPower, or Asus Sabertooth just for the looks) ^_^
