So I have finally ordered the parts for my watercooling loop. I will be cooling 2 GPU's and the CPU. Most will probably be overclocked, at least the CPU.
Everything is going smoothly, except I have no idea what to put in my loop. Some say distilled water + Nuke, some say silver coil, some say premixed. What do you suggest I use? Is there an optimal solution?
The store I am ordering from suggested I use this: https://www.techbay.no/product.html/aquacomputer-double-protect-ultra-1-liter
They said that distilled water+nuke and coil will make the water more conductive, thus ruining the copper in the long run.
Since it's clear it won't clog up the tubes, right?
All my blocks are copper, if that helps.
Thanks for the help!
