God damn it!
Mr. Smith
3dm05 crashes on the cpu tests... WTF?
CPU is occt stable, prime stable, 3dm06 stable, cinebench, gaming, whatever - it's stable so why the fook does it crash?
WHHHHY?
I tried the pro version, the free one, the hotfix... Bah.
Dono, tried 4ghz, then 3.6ghz...
4 = every other bench in the world stable
3.6/7 = 24/7 rock solid everything stable.
Might clock down to 3 to see what gives.... You got any thoughts?
Well if its passing at 3.6-7 ish then id just use that tbh.
You could try disabling some cores @ 4ghz, as 05 dont use multi cores at all iirc.
Sorry, I wasn't very clear at all:
3.6/7 = 24/7 rock solid everything stable - APART from 3dm05 cpu test!
I did a quick stock check and it will run at 2.4ghz. I'll disable some cores and see what happens...
3dm05 sucks...
i went up to 3.6 and had my ram at 500mhz 4-4-4-12, gpu was 765/1010 and it gave me 10k!!!!!!!
