First post to the forum and let me first say it was Tom's excellent Gigabyte OC video and guide that got me here and what a great bunch you all are! Thanks in advance to all. Even if you can't help me with the following problem, you've already been a tremendous help to my first OC adventure!
So here's the problem:
I OC'd by 3570K as per Tom's guide to a 'conservative' 4.3Ghz with temps and Vcore I was comfortable with under a variety of OCCT tests and Prime95. Vcore was stable at 1.224V under constant load and OCCT Linpack (which varies the load) it moved between 1.213 and 1.224.
Installed a EVGA GTX680 GPU yesterday and all hell breaks loose with respect to my Vcore. Vcore under load is now 1.320V (on an idle machine, it's dropping as low as 0.696V). Under the OCCT Linpack test it's also swinging more. Temps and CPU power consumption have risen correspondingly.
Looking at the Vcore swings, it would appear that the Bios is behaving as if the Vcore setting as 'Auto', but it has a set value (1.205V) and Loadline adjustment set to 'Extreme'. (for reference, the GPU settings in the Bios were left at 'auto' when I installed. I did not tinker with any OC settings on the GPU - it's entirely stock with the latest Nvidia driver 320.49 IIRC)
Any idea what's happened and how to fix (aside from yanking out the GPU)?
If my signature setup took, here's my system:
