Hey guys, new here and I hope that I have posted in the right section
I have been having some trouble with my new build. It froze after POST and in the BIOS after 2 or 3 minutes. I've looked all over Google looking for solution and i've checked all the hardware (had no soft on the pc yet) and went to exchange memory, which seemed to be causing the system to lock up. Memory helped a bit, the system worked a bit longer now without freezing and going into a boot loop.
My mobo uses different memory timings to the ones that the RAM is actually supposed to use (look below) and I think tweeking this might increase the stability of the system and remove the freezing problem. Any help on what to change guys? Btw. the cpu is stock with no o'c.
It's supposed to be 9-9-9-24 i belive. I changed that but the problem consisted and i'm still a newb and don't wanna change anything. Help?
Memory timings
CAS Latency Time 11
tRCD 11
tRP 11
tRAS 28
tRC 39
tRRD 5
tWTR 6
tWR 12
tWTP 23
tWL 7
tFRC 128
tRTP 6
tFAW 24
Command Rate (CMD)1
IO Latency 1
Round Trip Latency 37
Voltages
Vcore 1.223
DRAM Voltage 1.5
System
Intel Core i5 2500k @ 3.3GHz - Stock, no overclock
Gigabyte GA-P67A-UD4 B3 Rev. 1.1 Bios ver. F6
G.Skill RipjawsX F3-12800CL9D 8GBXL
Nvidia GeForce 9800GT 512MB
Enermax Galaxy 850w PSU
Thanks In advance
Memory timings
CAS Latency Time 11
tRCD 11
tRP 11
tRAS 28
tRC 39
tRRD 5
tWTR 6
tWR 12
tWTP 23
tWL 7
tFRC 128
tRTP 6
tFAW 24
Command Rate (CMD)1
IO Latency 1
Voltages
Vcore 1.223
DRAM Voltage 1.5
System
Thanks In advance
