Okay, the PSU will change to an RM 650. Which 780ti do you guys prefer for aircooling as I'll get him to change the case. His budget for a case is basically anything. What do you guys suggest?
If you get the Arc Minnnnnnnnni R2, you can stick with the mATX setup.
Other than that, it looks pretty good.
$99 could also get you the Enthoo Pro, a favourite case of mine, just saying. Either will serve him fine
http://pcpartpicker.com/part/phanteks-case-phes614pbk
Good luck on the build!
He likes the Arc Midi, so I wont bother changing it. If he really wants to, I showed him the link to this forum thread. As to the good luck wished on the build, he is actually going to build it... Thats the part that worries me, but he says he knows how. Ill link him to some videos just to be sure.![]()
Can you not help him in person and walk him through it?
Not much that can go wrong these days though. As long as he remembers to ground himself and can get the CPU cooler installed cause that one's a bitch :lol:
Just tell him to be very carefull with the pins on the motherboard, thats an easy mistake to make
how much more is the 4790K???
Hey mate,
I would recommend the following changes:
CPU: change to 4770, as not much point in getting the 4790 (if you can find 4770 cheaper)
Motherboard: find a cheaper H87/97 one instead, since they wont be overclocking
Videa Card: if willing change to 290x/290
Case: get the Fractal Define r4 instead (the Arc Midi looks ugly!) But if he likes the midi better then oh well.
Most of the above is assuming you want a cost efficient build.
Also tell your friend hes and idiot for demanding an i7 for a gaming PC![]()
Since he is going with the Arc midi get rid of the 212 and go with a nice AIO.
