G1.Sniper 3 Build...updated: Motherboard pics
G1.Sniper 3 Build...updated: SSD speeds and watercooling
Well Ive been looking at the water cooling components which i will get in a few months time. So far it comprises of:
EK FC680 Nickel/Acetal
Bitspower/EK compression fittings (not sure which)
Laing D5 with koolance top and reservoir
Alphacool NexXxos monsta 360mm (maybe also the 240mm)
XSPC clear tubing (will also take recommendations for better)
Mayhems Green Coolant (will add black and more green dye)
What do you people think? anything worth changing?
Don't use Tygon with Mayhems, they don't go well together.
Mick from Mayhems recommended me Clearflex 60 which is what i'm currently using and i've had zero issues with it so far :)
ok thanks BCMods for the tubing, ill go for that one instead....ive looked around before at the compression fittings and once again is it really worth the extra money for the bitspower fittings over other manufacturers?
Depends what your budget is really, but I can say that having used quite a few over the years, the first time I used Bitspower it put a huge smile on my face. They really are quality.
you could cut the cost down by using barbs instead of compressions. go for 7/16thID tubing and 1/2 barbs and you'll be sorted. goes on stays on, gotta be cut off the fit is that tight.
Also looks a heck of a lot better
i was thinking of doing that set up, as thats what TTL recommended, but i think i prefer the look of compressions.....but im still undecided so if money does become a problem i may just go with barbs, but as off now ill go with bitspower then
