Is it normal for the back panel audio to sound very different (and better) than front panel audio. Im just using some Sound Magic E10 earbuds and the difference is drastic. Should this be happening?
Yes, also depends on the case. Some cases come with better front panel audio cable/panel/connectors. The front panel is prone to ground loops and/or EMI
Always use the jacks on the back panel if you have a choice.
