Freeze on E7 error code on DP55WG HELP please!
Sorry what I meant was just to try the hard drive with a different sata cable than the one you've been using to rule that out. If you can go into the bios and monitor the cpu, then the chances are that that's ok. The only definitive way to test it though is to plug it into something else...
Yes but I only have 1 sata cable
Has anyone got any other info for me, to help me with this really FRUSTRATING problem
