Fractal Define C - Watercooled!
tinytomlogan
The Guvnor
Staff member
So it was said it would be too hard and too small..... But I got 2x 240mm rads and both a cpu and gpu loop in this rather compact case!
Good to see you back on the crack pipe (water cooling) :D
Hopefully I've had my fill now. Literally :D
Sweet build TTL!
Now I've got a question in regards to the CPU block. Since I really don't like the Eisbear, would it be possible to combine an Eiswolf + Eisblock + radiator + reservoir? The pump in the Eiswolf should be able to move upto 70 liters per hour on 12v, but I wonder if that would be enough? Obviously I would have to make a fill port close to the graphics card, which would also work as a drain port.
Sweet build TTL!
Im not sure about the eiswolf as the only pump tbh. Would make me worry about head heights - rad length and the pump pushing the water up and down it if it was in the front. So many variables with the lack of info Id say no. I had my pumps on 1000rpm down from 2600rpm to keep the noise in check too.
really nice build and shows a good use of these type of AIO's, I got asked to ask you where you got the Deadpool t-shirt and do they do it in 7 year old size
Finally sitting down to watch this at half 2 in the morning after doing a metric butt ton of paper work with a massive cuppa ^_^
Surely head height from the pump is never going to be more than the total height of the case? And any pump on the market can handle that? I agree, specs needed but I'd be super disappoint if a pump could literally not manage like what.. 36 inches? of head height?
You might have a point, but I guess I'd better ask Alphacool directly what they think of the idea.
that is pretty cool
that is pretty cool
Did you mean to quote SuB or just stole his post?...
Who the hell who are you??? a flippin mod IMHO you are just here seeking attention damn I get too much of that that from my 13 year old daughter
/end
