Hey Guys,
Just thought I would share a bit of info with the rest of you to solve a little problem I stumbled accross a while back about ACTUAL formated capadcity and how to work out what that would be. I did some research and put together the following guide that seems works pretty well.
If you want to know how much space you'll be able to use, just multiply the HDD specified space by a value of 0.93. The formatting method FAT/FAT32/NTFS/HFS etc, doesn't really matter. Just multiply by 0.93.
Technical terms, GB (gigabyte) stands for base-10 and GiB (gigibyte) stands for the base-2. When you click on My Computer and view your space, while it says GB, it's actually GiB. No one really uses GiB though, and so GB ends up standing for both, and that's where the capacity confusion is.
1GB = 1,000,000,000 bytes (how HDDs are manufactured)
1GiB = 1,073,741,824 bytes (how software actually sees and uses HDD space)
So heres a few common capacitys that people use worked out to their ACTUAL capacity using the formula:
40GB = 37GiB
80GB = 74GiB
100GB = 93GiB
120GB = 111GiB
160GB = 148GiB
200GB = 186GiB
250GB = 232GiB
300GB = 279GiB
320GB = 297GiB
400GB = 372GiB
500GB = 465GiB
750GB = 697GiB
1000GB = 930GiB
Hope this is helpful for people to work out what they need for OS drives etc and get a bit of education in the process. Took me a while
40GB = 37GiB
80GB = 74GiB
100GB = 93GiB
120GB = 111GiB
160GB = 148GiB
200GB = 186GiB
250GB = 232GiB
300GB = 279GiB
320GB = 297GiB
400GB = 372GiB
500GB = 465GiB
750GB = 697GiB
1000GB = 930GiB
