J jellybeard999 New member Apr 14, 2006 #1 http://www.pcpowercooling.com/products/viewproduct.php?show=T51XE that compatable with NF4 chipset boards you reckon ???
K K404 New member Apr 14, 2006 #3 Not directly compatable. Thats the server version, which has a different wire layout on the mobo plug. Thats the PCP+C I had, I rewired it fine. The "supported mobo" list gives it away K
K K404 New member Apr 14, 2006 #5 Grrr. I thought that was too good to be true, I got it very wrong. I was thinkingof the A4. The 510XE WILL work with normal mobos. Sorry bout that
J jellybeard999 New member Apr 15, 2006 #6 1x 24pin connector, 1x 8pin, 1x 4pin, 6x CD-Rom/HDD plugs and 2x Floppy Power Plug. Input: 100-240Vac 8.0A 50-60HZ Output: +5v @ 40A +12Vio @ 16A +12Vdig @ 18A -5V @ 0.3A -12V @ 2.0A +3.3V @ 45A +5VSB @ 3.5A Does that sound ATX2 to anyone else ??? ie 24 pin ATX connector, does that DEFINITELY mean ATX2 ? 12v rails... does that just mean dual rails, as im going to assume Thanks
