My blog is most uptodate with build log as I can not on forums at college
http://jackogara.info
Read the thread, I hope you understand what I say. ( good luck)
Basic idea.
Utility Flight Case
Put this lot in it;
Micro ATX Mobo
AMD x3
500w PSU
XFX 5770
Video capture card
2 HDs
Keyboard /Mouse
So the idea is to make a powerfull laptop.... kida.
Going to build in to the case a computer with inbuilt keyboard and popout mouse.
There won't be a battery it is not for that.
I will get a big flight case. Ones made for CDs are quite big.
The lid will hold the monitor and harddrives.
the lower section will have the PSU, Mobo/RAM/CPU, GPU and capture card in it.
Everythingwill be covered with a sheet of plastic that will have a keyboard indented into it.
There will be a draw section where the mouse will be and the power lead.
There will be a few fans taking in air from the left and spurting it out the right of the case. ( See epic blueprints)
In the top section there will be a panel with the mains power on and off, PC turn on. Power and HD activity LEDs. Lazer tags above them.
Also will have two;
showing temps of bottom and top parts.
Will have inbuilt speakers in top lid.
Epic blueprints made in PAINT.EXE!!!
It was either paint on windows PCs or FireWorks on Macs........
Constructive criticism or tips/ ideas.
Jack,
Ps, As I said most of this is on Aria's forum or my blog. Links at top of post.
Basic idea.
Utility Flight Case
Put this lot in it;
Micro ATX Mobo
AMD x3
500w PSU
XFX 5770
Video capture card
2 HDs
Keyboard /Mouse
Also will have two;
Jack,
