Elky72
Hello, First of all I'm a noob when it comes to overclocking. I know somewhat how it's done but have no experience what so ever. So please be kind. Also prepare for wall of Text
First I had a Asus 6970 2Gb version reference card. It was quite ok ran a mild overclock on it 915/1420/1.2V. Not a very cool running card and noisy but ok. All was well until I managed to brick it when I took it out so i could dust out my case properly.
Reason was probably static electricity. I'm usually very very carefull when it comes to somthing like that. I have reasonable experience working on hardware. It's the 2nd time I've had this happen and it was probably 10 years ago when I had this only other incident.
Ok so 6970 card ruined. Saturday morning I went to buy another one. Sadly they had no 6970 in stock, but they do had the Asus 6950 Direct CU II. I've remembered from somewhere you could flash a 6950 to 6970, so took this card home. Installed it ran it stock for about 30 mins and set out to flash it. Grabbed the 6970 CU II bios from the net and flashed it to the card using a bootable flashdrive and atiflash. Rebooted, reinstalled drivers and my system recognized it as 6970 CU II. Changed the power consumption settings in AMD overdrive to +20% as it was recomended by tutorial.
Tested the card it ran well, cool and quiet. It ran the 6970 stock settings 890/1375/1.17 as opposed to the 6950 stock 810/1250/1.1 . Ran benchmarks on it (Unigine and 3dmark 11).
Gamed a bit on it GTA4 with texture mods and Skyrim also with texture mods (Both 5760x1080). All was well no artefacting or freezing. So very happy with it.
Now the Direct CU II cards have a better cooler on them as the reference cards. The card ran like 54°C on full load. My previous bricked card ran like low 80's. So some more headroom for an overclock. After a whole afternoon fiddling and testing it I got it to 950/1500/1.27 . Benchmarked and game tested, it still ran below 70°C no artefacting or freezing. Truly happy and amazed it outperformed my previous card. Ended up playing GTA4 for 2 hours and went on to play Skyrim. Played about 4-5 hours I gues until it crashed, 2 screens went black the 3rd brown tints vertical stripes. Not so happy about that.
Rebooted my system and it just wouldn't run the benchamrk tests or any game without the same result after a couple of mins. So flashed it to a 6950 unlocked shader bios, with stock settings. But not all is well, have artefacting in unigine. 3d mark strangely enough not but when finished it directs me to the results webpage. Where it says card runs at 500 core clock. GPU-z show the stock clocks and registers the stock 810 clock in the sensors tab on full load. So ????
I can game, haven't tried GTA4 yet. Skyrim runs well for 2 hours more or less and then just crashes with black and brown screens.
Anyone have an idea that could fix this or did I just ruin 2 cards in just as many days
Sorry for the wall of text but I do want to explain my problem properly
