First WC try
Anyone else notice that alphacool logo is crooked? Other than nice build but there seems to be a tad bit more tubing than what i'm used to seeing. All in all a good looking simple loop. Should throw in a white led and let it shine!
Crusher: I guess you can't utilize the top rad ports on the right side? Sure would clean up that one big long tube. :) I did the exact same thing with my first loop. :D
Looks nice though, love the red tube/coolant.
thanks guys.
I have a nzxt 2m led strip arround the outside of the case i will take another pic with it on. and as for the rad if i had it either way around there would of been a long hose i just chose the way i liked the look of more.
*cough* *compression fittings* *cough*
we all have a first for everything guv'nor
They are not compression fittings.
Back in those days all the blocks were seperate thats why there is so much hose and trying to bend hose over so it can go into the block next to it is hard work! Back in those days 90 degree fittings were frowned apon because people worried about flow and 45's didnt exhist.
The only bad bit about that rig for the time it was built is the HDD wiring and the CPU power connector tbh
