NeverBackDown
AMD Enthusiast
H100i or Swifttech H220. Big increase in money but will be able to keep temps down much more at higher volts.
are you sure that a 128gb ssd is enough.
consider the samsung 840 evo it's just a bit slower but it's a lot cheaper
I don't think you need a 850 watt power supply, you can go with something lower wattage and use the extra for a 240GB or 256GB ssd. If your not getting multiple graphics cards you can get something around a 600 or 650 watt psu.
Something like this http://www.aria.co.uk/Products/Comp...+Bronze+Modular+Power+Supply+?productId=53656 would probably be enough.
Edit : but that is a pretty good deal for the AX 850.
I would never buy OEM Windows for a desktop PC...
It's for gaming so surely it has to be windows?
What i meant was i would never buy OEM for windows because OEM software will lock itself to the motherboard model # and if you try to switch motherboards you will not be able to boot and will basically lose everything on the drive.
Are you using the Gigabyte GA-Z87X-UD3H board you talked about earlier in this thread?
the 8 pin is the one you must plug in the other 4 pin is optionaleNo, opted for the GA-Z87X OC.
Currently installing h100i. Is the thermal paste that comes per applied fine to use, or would I be better putting my own paste on CPU before installation?
