I'm about to take my first step into building a water cooling kit, and I'm looking for some advice.
The Case i'm using in an Atex 1200, baught because I innitially didn't plan on using water cooling but now, I am, so i'm pretty much stuck with it.
My parts list thus far looks like this: (Copypasted straight from a website's shopping basket)
Swiftech Apogee™ GTZ 1366 (i7) CPU Block
- Barb Size 1/2" Nickel Plated
Black Ice GT Xtreme 240 Radiator
XSPC Bay Reservoir - Black
Xilence Pro Fan 120L 1300RPM 120mm (x2)
12V Laing D5 Vario Pump (MCP655)
1/2" ID - 3/4" OD Tygon R3603 Hose
- Hose Length 4 Meters
PrimoChill PURE Performance Coolant (32 oz.) - UV Blue
Black PVC Hose Clip 1/2" OD (10 Pack)
I'd like to get good quality parts, but not excessivly pricey ones - give or take £300 is going to be my upper limit. That list is my entire basket just now; I'm wondering - are the parts compatable, or is anything missing?
The design I'm going for is hanging the rad out the back of the case. I'm also only really interested in a CPU cooling loop just now, the waterblocks for the GTX295 arn't exactly cheap, and I don't fancy taking it to bits to get it installed.
Thanks for your help.
