I can do that of the mobo too and keep the pump clean lookingwith the fans on your h100i try and run them off the pump as you can use corsair link to keep the fans quiet when you need them and turns them up when your system gets warm
Thanks for the advice.i tried both and just found the curve was a little better on the corsair i just had to ofset the temps as the h100i is giving me a temp from the processor about 5-10 degrees under the temp core temps give me
Some internal pictures please![]()
yeah i did say they get lower temps but as i also said just adjust the link to have higher fan speeds at lower temps
All is looking good manCannot wait to see the finished project
May I ask, what GTX 670 you have ?
