Far Cry 2 overheats my 9800GX2
I wouldn't be able to tell you about the size mate... I do know the HAF932 is a good case, although a bit noisy at times. If you want it to be a little more silent a good fancontroller will help. You could check out the member reviews section for a review on the HAF and the kaze master ace fan controller :)
Of course both made by me :p
"of Course" ;) I did read reviw of HAF case and the size is perfect... it is only 2cm longer then my current chassis so it is a perfect fit + it is watercool aprooved so there is a future right there :) and i have a silence thingy to fill a chasis with, u know the one you glue inside your chasis and stuff...
Still have a bunch of that lying around... Should apply that some time but I'm too lazy :X
Sry ... bunch of what ? i didn't get that one ;)
BTW. that fan controll you are talking about is too flashy for my taste... too much going on there ;)
If the kaze master ace is a bit too flashy you might want to take a look at the normal kaze master (plastic/plexi instead of brushed aluminium) or the Zalman 5.25 Bay ZM-MFC1 Plus, which controls 6 fans, also making it good for a radiator in the roof.
And 'that' were case dampening mats, some poeple say it really helps making your rig quieter.
