is there software that u can run in windows that you can change the speed of the fans?? i have software that is suppose to work with my mobo from the same man. and it doesn't work right..
I was just wondering what fans you need to run..The Hyper6+ is pretty quiet so wouldnt need to be adjusted, also there is no northbridge fan on that mobo,
Speedfan is supposed to be able to adjust fan speed. I tried it myself and was never able to get it to work (then again, I didn't exactly try too hard) but my friend was able to do it.
