A AxJaWz New member Aug 21, 2011 #1 Found this on PC Specialist... Intel core i7 2600K Asus P8Z68-V 4GB DDR3 Integrated Graphics 350W PSU NZXT M59 Windows 7 home premium 64 The thing that bothers me is that it says the system will only consume 280 watts. Is this true?
A AxJaWz New member Aug 21, 2011 #3 So 24/7 folding with this with an i7-2600k. how much points would I get per day?
K kilobravo New member Aug 21, 2011 #4 You need a premium psu to hold the oc with no bsod or random reboots.Make sure the psu has low ripple and noise!
A AxJaWz New member Aug 21, 2011 #5 Im not used to low wattage PSU's. Can you link me to good low power and quiet PSU's?
K kilobravo New member Aug 21, 2011 #6 My i7-2600k @ 4.7ghz is giving 30-36k ppd depending on wu.Wu 6900,most common is 36k ppd.
K kilobravo New member Aug 21, 2011 #7 AxJaWz said: Im not used to low wattage PSU's. Can you link me to good low power and quiet PSU's? Click to expand... Low power premium psu are expensive,but this is a good deal. Be Quiet
A AxJaWz New member Aug 21, 2011 #8 kilobravo said: Low power premium psu are expensive,but this is a good deal. Be Quiet Click to expand... Does the fan run all the time or does it only run under load? thanks for the link.
K kilobravo New member Aug 21, 2011 #9 If it does it will be very quiet.90+ efficient it will run smooth and cool.
A AxJaWz New member Aug 21, 2011 #10 kilobravo said: If it does it will be very quiet.90+ efficient it will run smooth and cool. Click to expand... Thanks!
