Results of S/S unit with cheap single rad/pump and twin fan setup.
I started off with the same settings as Bazx 402a, 2.75mts of 0.31 cap tube, but different evap and suction line, the results where around what we had seen from Bazx, but this was using only a single rad and pump.
I Reduced the cap tube lenth for higher loads to 2.65mts and refilled with 402a.
all the results shown are un-insulated as i am awaiting on some insulation, so the end results should be a little bit better than shown.
The results are with two temp probes, T1 is attached to the side of the evap, and T2 is attached 6mm from the rear of the evap on the suction line.
The results shown where with the unit being run for around an hour at each test.
Pic of the S/S using single rad and know insulation.
Unloaded results:
High side 215 psi Low side 4psi
Unloaded T1 temps: -59.2c
Unloaded T2temps: -58.0c
very small amount of floodback, but this will be not be a problem as know load is on the unit, with only 50watts load applied the flooback had gone.
Loaded results:
303watt load applied.
High side 260psi, Low side 9psi
Loaded T1 temps: -33.9c
Loaded T2 tepms: -30.3c
Unloaded results:
Loaded results:
