pink
So I'm fitting a EK-FC680 GTX Full Cover Waterblock - Nickel Plexi to my GPU, I've removed the cooler, most of the thermal pads remain on the card as opposed to the cooler.
Firstly, the thermal paste on the big chip ... there was more of it around the chip, than there was on the chip. When it comes to cleaning it, I've been using TIM Cleaner and a Microfibre cloth, but the metal pins around the chip snag onto the cloth (which I've been doing my best to avoid). This means there's a mess left around the chip, and I'm not sure what to use to clean it or how careful I should be?
Secondly, I was looking over the GPU/PCB when cutting thermal pads, comparing where the old thermal pads were placed in comparison to where the diagram that came with my block said the new pads should be placed ... and I noticed there was a piece of string like fabric (not sure if cotton or acrylic) just over a centimeter in length mostly stuck under one of the larger thermal pads ... don't think it's going to cause any problems, but I was a little taken a back as I obviously didn't expect to find something like that, so thought I'd bring it up in case it's more relevant than I'm currently aware.
