errors
blair
i have my 10190T at this
200 fsb
20x multiplyer
1.48 according to the BIOS but cpuz says 1.44
i can log into windows but if i do prime95 test side bar stops working CCC stops and core 5 and 6 have errors
i have a asus m4a88td-v why do i get different voltage readings
up your volts
cpuz and bios never match up
im at 4.9v and 20 multipler and 200 fsb and crash under load
trying 18 ratio and 200fsb and 1.45v i logged into windows fine doing prime blend test now
i got voltages at manual in biod and typed in 1.45 but cpu-z how says 1.51v i dont want to kill the cpu
it seems stable at 18 multi and 200fsb and 1.45v primes been running for nearly 10 mins but LLC is on auto and voltage changes loads is this why its stable atm? ill try 1.47 and up the fsb to 210
whats the max voltage a phenom 2 chip can take?
depends on what cooling you are using!!!
if you are using the stock cooler DO NOT overclock too much - it will get too hot and you will be re-booted
push pull and i got side fan right next to it feeding it air
at 1.47v and fsb 210 and ratio 18 it seems stable so far
i disabled LLC
cpu says 57 and cores say 50 no crashed but temps going up
temps appear to have sabalized at cpu 58 and cores 50 which should i pay attention to and what it too hot?
