eddiep06's Rig Gallery - First Build
eddiep06
This is my first build with help from SPS
Parts used:
BitFenix Shinobi
Corsair HX850
Asus P8P67
Intel I5 2500k
Corsair Vengeance 8GB 1666mhz
WD Black 500GB
Sapphire ATI 6850
Moved to project logs as this isnt finished.
BTW that PSU is silly overkill in that rig, even 650w would have been overkill fella.
Should have chosen a bit better on that one dude
The reason i got such a big PSU is just to future proof really. im not sure what i will be doing that will take that amount of power, but now i know that i can
haha
The carlsberg went into me and scott as our power supply while we were building
:P
And as for the stock cooler, i am currently saving for a Noctua NH-D14. i work at mcdonalds tho so ill be another year or so ;P
haha
:P
Two overclocked 580's would probably use more than 850W
Niice
I'm gonna order my D14 this week me thinks, along with IC Diamond 24carat compound, that alone is £80> then I need a case & graphics card. That's another £300-£400...
Good to see you have a case, I'm dying to get my one. Funds are tight and I am doing this project without spending saving money, oh the joy.
Post some more pics of it all together?!
Niice
Hi mate,
Have you decided on a case or are you still spoilt for choice
Niice
The NT-H1 compound that comes with the D14 is more than good enough for anything really, mate
