ECS Modmen Case Mod Entry Fire & Ice
voting page (Spolier alert) http://www.ecsmodmen.com/entries/5123j26QWE95
Started working on the Floating tier for the MB. Thank you old trusting Intel for making a perfect template for Drilling holes for Standoffs
TAP, TAp, TAp
Found some arcylic Rods and wanted to incoportae them into the Build
Getting a idea on how its going to look
A last minute decision to make my own case feet
Mounted to the base
I am going to leave you with a teaser Pic
Seeing this progress makes me want to do something with all the plexi I have. A few years ago we had windows replaced in the house. My house was built in 1955 and the windows were in very bad shape. My mom and step-father many years ago had plexi "storm" windows put inside on the windows. They had a frame with magnet strip to hold them in, easy to take out to clean then. I took them off the 7 windows it was on before the new window installer got here.
I have 2 sheets 1140 mm x 1520 mm and the other 5 sheets are 1140 mm x 760 mm. It is about 4 mm thick. Not thick enough to edge fasten with screws, so have not tried anything with it and it needs polishing. I could make a lot of case windows I guess. :)
Small update,
using a small bit of clear epoxy to secure the sides to each other and base.
adding a hinge back panel
Installing hardware
water testing
Preview update coming later tonight.
Very impressive!! Love the resin effect you achieved. The only thing I don't get, dunno what the others think, is why is half the C in ECS missing?
EDIT: I've just realised the ECS logo has a strike through like that.. i retract my comment :)
It was a long a Fun Summer, Lot of exciting stuff for ICE Mod. I took it to Quakecon & a few Midwest Lans. Had over 5 interviews Quakecon and a ton of pics taken and in a article on CNN.
Adata Up their Game again and sent Some amazing memory. they are also making the memory with a Black PCB board
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211752
Here are just a few of the pictures of the ram and the adventures
Thank you for looking another update soon
A big thank you to XFX for sponsoring a R7970 and a pro 1000 watt PS for the final tour of the Ic pc, it was at LAN OC, Indiana Tech, FW Makers fair, IU Lan and of course setup as a Demo Station at FortLAN !!!
Thank you for Checking it out, I have 2 more projects coming up
