My core temps are reading significantly different values and wondered if anyone has a similar experience and hopefully a fix. I am dying for a fix because I don't feel comfortable overclocking this system until I know what are the real temps.
My system is basically:
* Intel E8400
* Gigabyte EP35-DS3P
* OCZ PC2-9200 Reapers
* Seagate 3GB/s HDD
The cpu is water cooled with 120x240 and 120x120 rads.
I flashed to the latest bios (F6a) and found that the temperatures (per Speed Fan) were pretty much the same – still out of whack. This was confirmed with Real Temp.
I tried the calibration approach used for Real Temp by dropping the core speed to 1.6GHz (6x266) and core voltage to 1.10v. The temp readings were 46/20 at idle (water cooled and RT at 18C).
Reset the core speed to normal 3.0GHz (9x333) and core voltage set to “normal”. Idle temps were the same (45/20) as the core running at 1.6GHz. The load temps were 51/33 as seen in Real Temp after running Orthos.
So the bios update did not fix the temperature readings and trying to recalibrate Real Temp won’t work.
Anyone run into similar out of whack readings and heard of a fix?
Thanks
* Intel E8400
* Seagate 3GB/s HDD
Thanks
