Dual Boot OClocking & Stock bios settings
nichos
Hi,
Has anybody come across of how to Dual Boot OClock & Stock bios settings so that the CPU is only OClocked when needed?.
I saw a write up of doing this once but cannot find it again.
Also anybody using ClockGen for OClocking ?.
Isn't Clockgen designed to overclock from the OS? I would much rather run an overclock all the time then do something like that.
Whats the problem of using it all the time?
NO PROBLEM Sir,
just asking if it is used by anybody for what it was made for.
And in fact, if I knew it was efficient enough I would use it whilst in XP when I want to use fs9.
And that would do nicely if the first Q in my last post proved negative.
I only use it so far to see the settings of PCI as my bios has no PCI setting facility.
