Drain Line in Loop?
winstonngo
I'm planning on doing a basic, CPU watercooling loop, using rasa rx 240 kit, in a CM 690 II case.
However, i'd also like to add a GPU waterblock at a later date.
Should i install the initial loop with a drain line, and how would i go about putting a drain line in, that looks tidy?
Ummm,
An RX 240 will only fit i the bottom of a CM 690 making a drain line redundant? So far as I'm aware
I'm planning on the same set up, same case, but with an EX and an RX 240, the GPU as well. You may be better off doing it completely custom. The pump in the XSPC kit isnt really strong enough to do 2 rads and 2 blocks, which is what you'd need for cooling the cpu and graphics anyway
