arnzzz
This is something thats been on my mind for a while but i can see it being difficult to implement
so never end up doing anything about it.
The problem:
I have space for 2 x 120mm fans on my door which inevitably when fitted are going to mean every
time i want to remove the door i will have to unplug the fans at the same time, then reattach them
again before closing the door. And i have the door off anything up to 10 times a day lol.
Now i can live with this i suppose
		 but i was trying to think of a clean elegant ways to solve this.
if i had a workshop with all the tools maybe i could do this, but i dont know how much i trust myself
to start hacking away at my new case with a dremel.
Solution = 2 small copper contacts on the case which are wired to a fan controller or other power
supply of your choice, and 2 more copper contacts on the door wired to a small block connector
to which the fans could be connected directly to. So when the door is removed contact is
broken, then when the door is replaced contact is made and fans resume work
		 EASY
	 EASY
Give me a few weeks and maybe ill give this ago, if i can make it work without hacking away at
my case.
Anyone else made any attempt at solving this, together we could change the future of door fans
The problem:
my case.
