instead of spending £££ on buying a side window i'm thinking of cutting the case side panel with a jigsaw and then getting a piece of plexi glass from my local diy store.
so just wondering do i drill a hole so i can fit the jigsaw blade in the panel to start the cut, or my friend recommend using a Dremel.
