Display is not coming
mwvirk
My computer shutdown automatically.
Later I tried to switch on the machine again but it (CPU) gave 1 long beep and then 3 beeps.
On monitor, it shows that it's trying to find signals (showing HDMI - Digital - Analog) and then monitor goes to standby.
Open the case and found that display card's (8800GT) is stopped and its not working at all.
Remove card and clean it. Still fan was not moving. Clean fan properly and used WD40 and fan started working now.
Placed card back and cabled. But still machine is coming up but there is no display. CPU is still giving 1 long beep & 3 beeps and monitor still showing HDMI - Digital - Analog.
I wonder if GPU is dead!!! But how come fan is working. Do i need to buy new GPU now. Pls help.
Try removing ram and re seating it all too.
After a little googling, wheneople get those beeps they say they removed gfx card and ram then when they put them back it worked
Also it is your motherboard not your CPU beeping
won't be a RAM issue, Ram issuses usually are shit loads of spazzy beeps depending on the system. Could be a power issue as my old GPU used to screech at you if you tried to turn it on without the power pins plugged in. If windows randomly shut off, the fan on the card could have failed and it could have over heated, usually windows shuts off at around 100 - 120*c to prevent further damage.
Look at your machine, see if theres any hard drive activity, if there is then its most likely a GPU problem
ok. i got response from most of forums that it could be GPU.
well, I am going to confirm this by installing some other card on my machine and try my card on some other machine.
now, if it is really GPU then i need to buy a new display card. Please help me find good DX11 card based on my mobo / sys config.
please help me and let me have list of few DX11 card with rating.
(ASKING LIST OF FEW DX11 - SO I CAN CHECK MY BADGET)
I would advise looking around this website at some GPU reviews if your looking for different opinions, and the overlock3d youtube channel.
