Display Driver Uninstaller 12.9.5.1
Dicehunter
Resident Newb
Thought I'd start posting new updates of DDU as I know a lot of people use it.
Handy for when you've uninstalled the main bulk of GPU drivers and want to remove any trace of them for a clean driver install.
After you uninstall your drivers restart in safe mode *Recommended by the program creator* and open up DDU, You can select which driver you want to remove, AMD, Intel or Nvidia but it should select yours automatically.
Uncheck save log files, Only needed if you have an unstable system and need logs.
And finally click clean and restart, This will clean the system of any left overs from the GPU drivers and will also restart your system into normal mode where you can proceed to install your new GPU drivers.
Click Me For the Latest Version
Change Log For DDU
12.9.5.1
-Additional Miracast Cleanup (For nVidia 340.43)
-Additional Intel CleanUP
