Disable External Drive Auto Sleep
Toxcity
Afternoon all,
It has been a while since I have been on here so OH HERRO!
Right, my issue is with one of my external hard drives. It's a Hitachi XL Desk 1TB and I have been using it for Xbox storage but my issue is that it shuts itself off after 15mins of idle. This is fine on a PC but when trying to run a game from it on a 360 the 360 complains and sends you back to dashboard.
Now this shut off feature is built into the drive, I have tried using certain Linux programs to disable it but nothing so far has worked.
Any ideas?
gief soloutions plox does want to fix mai derp drive....
What's the exact model? Hitachi has a tool called FeatureTool that you can use to disable/enable certain features. I'm not sure if this is one of them, but it's worth a shot. Go into their support section for your model and you should see the tool listed under downloads.
hmm, well it should be a normal drive inside the USB cage. Is it still under warranty? If not, I'd pop the case open and connect the drive directly to your PC.
